krawler98
Always wrenchin'
- Roanoke, VA
What would cause the constant draw?
On a b piped setup sure. A power factor pipe needs timing pulled back at higher rpm to make the pipe work the way it needs to. The enhancer curve does not retard the timing much at the higher rpm points. This is where the epic really shines, it's just a matter of getting one that actually works.can you get away with advancing the static timing on the stator 3-5 degrees when using an msd enhancer?
Enough of a draw that by the time I got home from the lake yesterday, a 45 minute drive, that my battery was dead. Tried two different batteries and it killed them both. Didnt start til I swapped in 61x cdi. Could I have hooked up wires wrong somewhere? I may try to swap epic back in and see if I can get it to workWhat is the draw on the battery when the ski is off? have you tried swapping other components and battery? Will be interesting to hear if you get a replacement for free,or the same unit sent back with everything is fine sticker... Try it in another ski before you send it off....
