Well I wondered the same thing, first found changing and tuning the curves did not eliminate the issue. So I bought a degree wheel, positive piston stop, timing tap, a front cover to cut, I determined true TDC, made a bolt on pointer, installed my tap and started examining the timing with a light and a flat curve of 21 deg. Found timing did not hold 21 deg and was all over the place, but had a more prominant 10 deg retard in the 1500 to 3k range. Next I used the offset with no improvment to fantom 10 deg retard. Next I mapped the timing as it changed and recorded it on paper thern drew a custom curve to compensate for the irregular timing, re-tested found fantom retard still their, Next I drew a square wave curve to test and found the HX3 followed it exactly, now Iam like this make no sense and is inconclusive, maybe their is something else besides timing occureing that iam missing. Next I installed an ocilliscope and measured spark voltage and examined its wave form, spark KV at idle speed 11,000 volts and 22,000 during a no load snap throttle test, wave form revealed that not every spark was reaching this voltage, some spark firing lines were only 1000kv. Next I did a cranking spark test and this was really revealing, after the start phase, I found that spark did not occure at every TDC of the piston, approximately 4 spark events in 10 piston TDC's accompained with a thin blue spark. Next I installed an OE flywheel and re-performed the above tests with exception of the scope test. The HX3 held the timing true to the curve no matter where i drew it, the HX3 followed that curve exactly. Did another Spark test, found spark occures at every TDC event and has a thick, bright yellow spark that when video was taken you could see the blue spark inside the yellow spark.
These tests were not perfomed under load, the engine runs fine on the stand, but symtoms become noticable while on the trailer under load or while water testing so we could have even more annomalies
Chris and Lisa at AirTime were very helpfull during all of this and went over my flywheels type and age early on, we tried the OE, 116 & 117 flashes too. Chris is the one who suggested trying an OE flywheel, kudos to him.
My MSD and Pro Tec cdi's worked fine with that TBM flywheel.
The HX3 works great with a lightened OE flywheel.
Just a heads up
