- Tuscaloosa, AL
Get the manifold then get an adapter plate made.Can you please make this for kawasaki 750? I dont want to pay 1200 for a complete used system.
But there is also the headpipe which I think is totally different between the two. For a 750sx and sxi you also have a different (rear) waterbox location.Get the manifold then get an adapter plate made.
Yes there will be a chamberAre you gonna make chambers eventually as well?
We are working on them now. We have made some changes to the header pipe as well. The original header pipe dates back to the 550 days. Sure they were a two bolt but all the rest is the same. We have changed it to bring it into the present day. All will be shown soon enough. Thanks for your supportOrdered a manifold, need 2 headpipes please!![]()
i was gonna say, surely youre not just copying fpp design and not making anything better than they were doing haha. be good to design the headpipe so the screws dont seize up or some how machine the pipe so the water has a better spray pattern similar to like a spraybar that the laydown pipe guys set them up as a wetpipe.We are working on them now. We have made some changes to the header pipe as well. The original header pipe dates back to the 550 days. Sure they were a two bolt but all the rest is the same. We have changed it to bring it into the present day. All will be shown soon enough. Thanks for your support
Like a base you fibre glass into place ?Just purchased the exhaust manifold and will purchase the whole system eventually. Any chance wax will make a fuel tank cradle for their fuel tanks. I found them to work great with the cold fusion tanks to keep it in place
Yes I ran a blowsion one and used 5200 to secure it in the hull. Worked great tank never moved again and if u ever wanna remove it it’s only a bit of 5200 around the edges and base of it. Anyways keep up the good work your products look great and can’t wait to see the complete exhaust systemLike a base you fibre glass into place ?
Thanks for the heads up. Yes it’s something I have been looking into. Appreciate the ideasYes I ran a blowsion one and used 5200 to secure it in the hull. Worked great tank never moved again and if u ever wanna remove it it’s only a bit of 5200 around the edges and base of it. Anyways keep up the good work your products look great and can’t wait to see the complete exhaust system
Ok well here it is. We have opened up the pre-buy on the b-pipe exhaust manifolds. Header pipes coming soon enough
This is a limited amount on the pre-buy
Factory B-Pipe Style Exhaust Manifold Yamaha
After a long search, we’re excited to finally offer these manifolds! Designed to run hotter for improved performance, this manifold does not feature cast-in cooling. This approach has shown to yield better power results on the dyno for Yamaha engines, thanks to a tip from Tim Tynan. These...www.waxracingproducts.com
