- Asheville, NC
Great info! I use some nice silicone hose that would stretch over the 1/2” no problem. So, I’ll cut the 1/2” cooling tubes and use those instead.
So, I’m having some major trouble today with the steering cable holder in the pump area. I filled the old hole I had cut so I could relocate the holder. I have it marked in an area that I can fit a 27mm socket over and also clears everything around it. However, the center line of that hole is right at the center of the steering nozzle mount. So the cable completely centered would have to flex downward to be able to connect to the ball on the nozzle. This would be exaggerated when using the trim and steering hard left or right and looks like it will bind the cable. I thought of maybe putting the ball on top of the nozzle and moving the hole even further up, but it seems like the tabs on the pump and reduction nozzle will be in the way of steering… I need some ideas because this is pretty important! Take a look… again, the center of the marked hole is centered with the mount on the steering nozzle. No good…
