I’ve been busy with another project and needed to get it out of my way and parts off my work bench so I haven’t had any time to work on this hull. However, I got the other project all finished up and started back on the FX-1 yesterday afternoon. Sometime in the past couple weeks I had a minute to cut the exhaust and shape it nicely to fit this hull. Also, big thanks to
@mikesx for sending me some schedule 80 PVC! I was able to get it over to a buddies shop and make use of his lathe, creating a perfect through hull tube. Take a look!
I also hand cut the exhaust to match the hull, came out smooth! Is there any reason I shouldn’t have the tube extend into the engine bay so far? I think my SJ is about the same…
For some reason the hole for the exhaust exit got elongated, you can see a lot of space around it in the pictures. I’m thinking of wrapping the exhaust in packing tape and filling the gap with thickened epoxy… not sure if I should just 5200 it instead, those gaps are pretty big.
Lastly I was able to get my cooling lines cut to length and de-burred. I couldn’t decide wether to go with 1/2” lines or 3/8” lines and in the end I decided to just stick with 3/8” lines. I will be running dual cooling and spoke with Paul about 1/2” dual cooling and he said that it could be borderline too much with the 735 Shredder engine I will be running. I honestly have no interest in running some huge cc engine and decided that 3/8” cooling should be plenty for anything I will ever run. I also got my trim tube cut into place and cut the tube to length. I decided to use a 5/8” line for the trim because it seems like the 1/2” line doesn’t make a good seal on the rubber outlet piece… any reason I shouldn’t use a 5/8” tube?
This is the 1/2” line
This is the 5/8” line with the rubber fitting…
