Thanks!
Yes the chans have hood air intakes and havent had any breathing problems
Sent from my SM-N975U using Tapatalk
Thanks! it was well worth it!Those a really nicely hidden! Nice looking ski man.
Some one must have added those mine doesn't have them lucky I only have 701 for now i will have to make some see if it lets my junk breath
Also when I had the motor I had the two exhaust manifold going out so there was a total of 4 pissers.
Sort of. Im still new to these type of hulls and motor setups so Iv started to notice that I can just leave my ski floating in the water for a long period of time and I believe after a while the motor starts taking on water and it doesnt like to start after that.did you ever find out why the ski decided not to start back up at the end of your test ride?
I think i accidently found my starting problem todaydid you ever find out why the ski decided not to start back up at the end of your test ride?
I have just been excited to ride it probably put about 12 hours on it i really just tuned it enough to have some fun but i know i am missing out on a lot of power right nowHad maybe 30 minutes on the top end before I sent it to you so it definitely needs a tune
so what exactly broke the case?
did you just epoxy the broken case back together?
are you not running o rings under that head? I saw a lot of what looks like threebond. looks like some moisture got in there for sure, the cyl walls looked rusted.
did you ever fix the pump issue?
Well this semi sucks I guess i already had race gas domes unless .3 of a cc really matters lol was hoping to squeeze out more power
Sent from my Note 10+ using Tapatalk
