D-Roc
I forgot!
- Dirty River Rider
Matt, I am telling you I had hot cables from a bad starter, It also killed my battery fast from a few starts. i don't know all the fancy term but in my mind it was like i put the positive cable and hooked it to a ground and held it. of course it gets hot if there is no fuse to blow, if the starter uses the power and spins freely and easily the battery lasts, but if the starter is crap, it grounds out the power and gets dispansated in the cable by heat. I know you do not have hot cables but, you could have a crusty starter that the jetworks battery may not be affected by as much as this toy battery. the currency increase from a bad old starter. yes? no?
