- Near Seattle WA
Rotary switch.
Best solution.. $38.00 http://www.watcon.com/Catalog_Pages/Rotary_Switch.htm
Thanks,
Randy
Thanks,
Randy
inline fuse holder but even then, you have to replace the fuse every couple months because the metal cap comes off the glass tube.
I tried one of those also. It didn't work well in my ski because the constant up and down motion of the ski where I ride made the pump turn off and on constantly and the switch burnt out in a short time.
The same one? I have never heard of one fail, however, I have not heard of a switch except for twisting the wires together that has not failed.
I'm glad someone knows what there talking about in this thread. Always switch the power!The bad thing about switching the ground only, 12VDC is present at your pump at all times. DC and moisture do not mix and it starts to build that green corrosion with even the slightest path to ground. You may find that your connections and pumps do not last as long.
How can 12VDC be present at your pump at all times when the circuit is not complete/ off ? just asking....
I have a few years in the auto electronics industry, wired a few boats and touched a couple planes. I have been running my bilges this way (switching ground) for years and I ride only saltwater.
Quick question, what does Yamaha switch (+ or -) on the start switch? How about the stop switch? I realize they are momentary switches, but the logic is still the same.
we can agree to disagree too (wont hurt my feelings) :silly:
I'll pick up one of these switches for sure when mine finally dies.
