waxhead
wannabe backflipper
- gold coast
We have been making a new head for the 62t engine with a proper shaped combustion chamber. Its always nice to make things backwards combatable so we will make the heads use the same style of dome as the ada. This means you can buy our domes and use them in the ada head and you can use the ada domes in our head,
The had part about this is due to the ada head not having the spark plug in the vertical center of the combustion chamber to make it backward compatible we have to run a longer spark plug. This makes the plug more expensive. Would you be prepared to pay more for the proper chamber shape ??
The plugs are about 20-25 each
What's your thoughts please.
