ArtMaybee
I'm Baaaack!
- Mobile, AL
I just got my black anodized part. It's great! Awesome communication from the seller and super fast shipping.
Regarding pole stop.. My stock SN bracket had a long rubber 'block' under the hood hooks. I chopped this in half and installed it... it actually acts as a pole bump stop... of course running a limiting rope as well.
I made this bracket for myself because I didn't like the other options for the conversion out there. A few people asked me to make one for them, so I've been having them made in small batches.
With this bracket, you can use the existing pole bolt and hood hooks (in their original locations) and rubber hose cover. It is designed to use the RN spring. There is enough up-travel to get the hood off with an un-modified pole. So basically all you need for a conversion is a RN Pole and spring. Everything else swaps over. I do not have any up-stops built in, so a limiting rope is recommended.
I've heard some concerns about the lack of a pole-lock to hold it up. If you use an aftermarket RN spring, it will hold itself up almost all the way so the stop is not needed.
The newer (08+) Poles are a little different than the 96-07 poles so I would recommend using the latter. (latter meaning latter in the sentence - meaning Use the 96-07 pole!) Here are a couple of links for how to identify your pole and what you can do if you get a post-07:
how to tell 08 poles from earlier ones?
Modified cable mount by Flash-FX
Let me know if you are interested. I have these made in small batches and get more when I run out. Price is $125 plus shipping for a plain aluminum finished bracket. $150 plus shipping for Black or Clear Anodized.
Update: I had one person send in a picture of a pole spring that didn't line up very well with the spring hole in the bracket. It was at an angle and was locking itself in position. If you run into this, bend the leg of the spring slightly so that it can move (see crappy drawing) The spring should be able to pull in and out slightly as you move the pole.
See the rest of the thread for more installed pics!
I have also made some replacement backing plates (Shown below) These are not included with the bracket, but are available for $20+ship.
