Isn't it more proper tuning than anything else?
Not really,when you start modding engines it is hard to get it have good idle quality and have good bottom end snap,the way it usually works is the low speed is set over rich from where it actually needs to be to have the best idle quality.
This allows the engine to pull through the transition circuit to the main jet circuit, if you were to lean the low speed out where it idles properly then you will have a bog when you take off.
On some of the sitdown craft they have installed accell pumps to correct this,it is done mostly to clean up EPA emissions but it does allow for a clean idle and when you stab the throttle it gets a shot of extra fuel to carry through the transition circuit to the main jet circuit.
The circuitry on the Blackjacks is quite unique and was developed after many hours of testing on the flowbench,it pulls fuel immediately when the throttle plate is opened allowing for a clean idle and the awesome low speed hit that all the freestylers seek.
