Boyer's Murdered out 2010 SS865 Trinity Matrix "ES" Build, (Now -2") :biggrin:
OCD Solutions
Rentz, GA
The wife and I are headed north tomorrow to go pick up the new hull. 951 miles each way. Leaving right after work friday and hope to be home by 9-10 sunday night.
OCD Solutions
Rentz, GA
Google maps says 15hrs, Joe says a little over 12hrs from Charleston so we shall see.
I'll let you all know on Monday how long it took.
Sent from a POS Galaxy S3 :banghead:
Ducky
Back in the game!
Charlotte, NC
I live in Binghamton, NY and you will pass right through. It is about an hour and 30 minutes south of your new hull. If you need anything, 607-341-3571
OCD Solutions
Rentz, GA
Most likely. Trying to think about what I want to do to it but my brain is shutting down. My wife is taking a turn behind the wheel as we have now been on the road nonstop since 4:30pm yesterday. (going on 19 hours now). GPS says 12 more hours to home but Amex is saying get a room and recharge.
OCD Solutions
Rentz, GA
Finally home! Left Friday night at 4:30pm and got home today around 2:30pm. It took 42 hours and 5 tanks of fuel to go 1900 miles. We left right after work on Friday and drove all through the night, picked up the hull saturday morning and made it another 7 hours before finally stopping for the night. Got up at 4:30am this morning and drove the last 9 hours home. With traffic, accidents and general stops it took 16 hours to get there and 14 to get back.
uploadfromtaptalk1370205108171.jpguploadfromtaptalk1370205118908.jpguploadfromtaptalk1370205129067.jpguploadfromtaptalk1370205139096.jpg
Just so you don't think we know how to stop and smell the roses, we made one small detour and checked out the Crystal Grottoes Caverns. Very cool and well worth the $20 entry fee. They said we couldn't take pics so the website will have to do.
http://www.crystalgrottoescaverns.com/gallery.php
Pablo
sqeez bth levrs & lean bk
georgia
Boyer ur a hard charger! I'm impressed. Is the layup/construction different? I read where u said the pro model is lighter. The new hull looks sharp. Congrats.
az
6 Months to gather/sell and prep parts and wait for everything to arrive,
3 months of petting my X-Scream engine on the bench telling it, "Soon, baby soon",
16hr round trip down to Florida to pick up the hull,
4 days of staring at everything every night after work just waiting for the weekend to assemble
15 hrs to fully assemble ski and get it running,
10 hrs to do a mediocre turf job that will last forever,
5 more days of work until the weekend and my first chance to ride...
And it was worth every second of the wait!!!!!!!!!!!!!!
LET THE RIDING BEGIN!!!!!!!!!!!!!!!!
Misc Specs:
Trinity Matrix ES Hull (-2")
Hull weight: 105 lbs
Hood weight: 14 lbs
Assembled dry weight: 318 lbs
Ready to Ride weight: 350 lbs
Compression 195 lbs
Hull;
2010 Trinity Composites Matrix "ES" hull in Black Gelcoat, 119 lbs with hood
Trinity Footholds
Hydroturf Diamond groove Mats with 9mm Underpad in the tray
Dual 500GPH Bilges with Billet 45° Fittings and rotary switch on dash and Tidy Bilge Harness
ATP Performance Waterbox
Stock Fuel tank with Wamiltons Billet Internal fill
Thrust Innovations Billet External Fill
Versiplug-R 1" rear drain
Engine and electrics;
X-Scream SS846 Billet cylinder kit (annodized black) (195 psi)
OEM Trued and Welded crank
64U Cases ported and epoxied by X-Scream
Boyesen/Full Spectrum Extreme Velocity Intake
Dual Mikuni 46's modded by X-Scream and painted black
B-Pipe modded by X-Scream, (limited chamber) and ceramic coated by airborne Coatings in Denver, NC
Prok Filters with Outwears
JSS 62T Stator with JSS Stainless Laser cut washers
JSS Coil
JSS Battery and Starter Leads
TBM Lightweight Charging Flywheel
Cold Fusion Billet Flywheel cover
Billet UMI lightweight couplers
ATP E.P.I.C. programmable ignition Module
Deka ETX-14 AGM battery
Custom aluminum mini Battery box
GP800 Motor Mounts with Kenney Keepers
Pump and handling;
Skat-Trak 144mm Magnum Setback Pump
Skat Extended setback driveshaft
14/19 Skat C75 Impeller
Skat Nose cone
Worx 201 Intake
Stock Superjet D-cut rideplate
Sato Engineering Reduction and trim setup
New OEM stainless wear ring
Steering and handpole;
RRP Handpole with black annodized tubes
RRP Dual breather bracket
RRP Chinpad support bracket
RRP Pole Spring mount
Stock modded pole spring
UMI Sealed bearing steering system
X-Metal -2.5" Turnplate
X_Metal Straightbars
Wamiltons RRP Chinpad
JSS Start/Stop switch
ODI Grips
ASV Trim Lever
SE Trim cable
Wamiltons Finger throttle
Kawi 650sx Throttle cable
Hot Products Adjustable Throttle Drum
attachment.php
attachment.php
attachment.php
attachment.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
Very nice
OCD Solutions
Rentz, GA
From the Trinity website;
Our MATRIX Pro hull construction process comes from our extensive knowledge in aerospace technology. We start with an epoxy primer providing a light and fracture resistant surface. Next we precisely laminate our hull. A combination of carbon fiber and Kevlar fabrics are placed in molds engineered exactly to specifications. Composite fabrics are infused with aerospace grade high temperature epoxy resin. This resin provides a higher tensile strength than any other available today. The final step in lamination is to vacuum bag our components.This provides laminate consolidation resulting in a lighter and stronger product. Once the components are fully cured they are removed from the mold and inspected. The components are then glued together with the best methacrylate structural adhesive and secured with quality hardware. Using this controlled process we are able to ensure that every MATRIX hull is of the same caliber as the next.
It feels much lighter than my ES hull but the scale says differently. I was expecting it to be at least 30 lbs lighter but it is more like 20. Hull with turf, footholds, hood seal, ratchet strap and dual thrust pump dumps is 95lbs, hood with breather tubes and pole crush pad is another 10.5lbs. Total weight is 104.5lbs where my ES was 124.5 lbs.
The hood is super thin and it's very noticeable in the hand hold area that the outer skin is less than half the thickness of the ES hood.
Work permitting, I plan to assemble it this week and have it ready for the following weekend.
