- US
You mean you don't think the 650 will do? I never thought about that.It takes a lot of power to make a short boat work.
Sent from my SM-G960U1 using Tapatalk
Advise wise,plan five steps ahead,(and put some shoes on or at least flip flopsI don't keep track, its 20-30 minutes every time I work on it. I sand and shape for 15 minutes then lay down some glass. I use a 3:1 epoxy so I try to prep just enough area to use 4 oz of epoxy which isn't much. I always do the first layer with a thin tape to make sure there are no air bubbles and then ill do 2 layers wet of heavy fabric twice over the top of that.
I don't really have much of a plan on paper, so I just look at it when I get out there and start working, so I've had to re do multiple areas or scrap ideas halfway through a few times. If I had to guess I'd say maybe 80 hours so far.
It weighs 40-50 right now with no pole, hood, or pump. I didn't weigh it before but I cut about 15lb off of it.
I'm glad you are curious about the process, I always have been but noone really posts the little details and steps of the process that seem boring and insignificant, but the truth is this whole process is just a ton of baby steps, and you don't have to be a pro to do it. All you need is the guys to chop up your ski, a little general knowledge of epoxy and fiberglass, a lot of sandpaper, and the ability to function with tiny shards of glass in your hands and arms everyday lol.
Got tired of sanding. So I just shot it with primer, I'll bondo all the ugly spots. I think ill have a little texture for the base coat to hide the imperfections and help negate scratches.![]()
Alot of good info I appreciate hearing from someone who has been there done that! Did you run the pipe dry? I can't imagine running it at full throttle and then coming off plane to jump or stunt would lead to water ingestion.
I've been wondering about creating a high point in the exhaust, especially with my loss of buoyancy from the smaller hull. I've had this ski for a few seasons and never really had an issue before, so I didn't think about it.
I may to add a scupper valve of some sort if it pulls in too much water.
In all reality this project started as $50 junk ski and it has morphed into "just get it out of the garage and on the lake" now that I've got 4 kids, also I just picked up that 750sxi and a waveblaster 1.
If I ride without a lanyard, even in the surf and it idles when I fall of would it still be a bother? Ive rolled it a few times and it never turned off. The surf here in Texas is really pretty minimal.
The sharp corners on the gas cap cover?Your knees and shins will not like those sharp corners.
