Spent little time in the garage today. I extended the steering linkage and moved it in a little so it will work with my trim nozzle. I also moved the steering ball in about 1/2 inch for a cheap quick steer mod. I welded it so that I can just do a little grinding and have it back to stock incase I need to get rid of the trim. I might still need to move the one on the handlebars out, I'll see how much it wants to bind up first.
I also enlarged the manifold holes and ground 1/4" off of my pipe hangar to keep the Pipe away from the hull. I wish I could have thought about that before I nodded my hull. There's plenty of room to squeeze it in with this method. Probably up to 1/2" if needed.
Got a new skat 15 and chucked my old prop.
Printed a pteg tailcone and filled it with grease.
I'm also working on a new fuel pickup. With my chopped hood, the fuel lines are getting pinched coming out of the tank. I can't get it airtight though.
Sent from my SM-G960U1 using Tapatalk
