Custom/Hybrid Canadian Freestyle ROK Rebuild
steve-uk
Manners cost nothing
Barrie - ontario
when you first install a pfp it looks like there is a ton of room... but actually there is not due to the shape of the chamber, the shape of the rok then compounds that.... these tanks are 8x8x14
depending on your hull you could maybe squeeze in a larger tank, on the rok this seems the best option
steve-uk
Barrie - ontario
motor is all painted up
got my pfp back so might actually be able to start making some progess
attachment.php
steve-uk
Barrie - ontario
thanks guys.. credit has to go to doug....
started looking at fitting the ATP adjustable intake grate
looks like i will need a plate for sure, was trying to do a couple strips but not looking right
steve-uk
Barrie - ontario
So im thinking of maybe bolting a plate in and then glassing over it, that way i can build up the void and i can make a "ramp" towards the top of the grate
would have been so much easier if the rok didnt have this crazy pump design
attachment.php
attachment.php
attachment.php
attachment.php
steve-uk
Barrie - ontario
finally some progress......
attachment.php
lent out my pfp manifold so im waiting to get it back.... bill.....:)
also waiting on carbs.. seem to have sold mine ... oh.. and the intake grate!
hopefully will be ready for wavedaze so i can do my mandatory 20 mins of riding!
steve-uk
Barrie - ontario
well im still waiting on a couple of key parts but i decided to fit the pipe
lets say anyone who says "im going to throw a pfp in" is in for a rude awakening, this has been a b!atch to install, its in.. but strapping etc has been .. erm fun??
attachment.php
i was planning on running a 3 gal jazz tank, but unfortunately in the rok that aint going to happen, hood wont close... so its back to the 9ltr cark tank.. from what i understand the pfps are thirsty and with dual 48s i will be spending some time refuelling!
as you can see everything is tight, water box is not sitting at the angle i wanted but the hose will "help" to pull that back, to get the compound angle for the chamber to exit the manifold and then enter the water box it makes the filter/flow valve assembly very close to the underide of the nose at the front
attachment.php
and no to add insult to injury i cant even put the kart tank in at the mo as i dont have long enough straps left :banghead:
the way the chamber has to be strapped in the rok to create these angles im worried will put too much side load on the motor, i guess we will see
but at the moment i dont have my domes in so i had to throw the head on with a couple of the girdle nuts as without bolting it down the pipe once strapped was pulling the cylinder over
steve-uk
Barrie - ontario
im hoping so brian, its been certainly an experience trying to squeeze it in
my carbs are due to ship to me around 16th so ill be riding this ski for the first time at wavedaze....
Looking good Steve. I'm going to try tackling my PFP install in my Freak this weekend. I'm not looking forward to it. My hull is set up for a B-Pipe with stock tank and stock battery location.
I'm also wondering what to do about the hose between waterbox and thru-hull tube.
steve-uk
Barrie - ontario
best advise i have on strapping the water box.... i put hooks in and went over the top
i wish i had put the hooks on the side of the hull and strapped that way would pull the wtarebox a little and help with hose alignment!
installing the pfp really is a step by step process, i pulled the chamber out a number of times, strap size.. frustrating
the "hole" left for the tank is tight for the Jaz, i noticed the tank if positioned wrong will hit the inside radius of the chamber
im going to try to see if there is another way of strapping the tank in, Bill and Daryl just came round and gave me some fresh ideas
i only have a 90dgeree hose here, im going to see if i can cut it at 45 and make it work
on the bright side the space by the bulk head is nice to see.....
Matt, if you dont have your hooks already glassed in you may need longer than a weekend....
