Cannibal
Tasty Human
- Summit Lake, WA
Primed this evening! Such a milestone.
I knew there was going to be some minor things to fill, but holy pin holes batman. It's fine though, I'll be able to use the Blaze Glaze I have over the primer which I couldn't do over the epoxy because of compatibility issues (polyester on epoxy).
My plan is to fill the flaws and get it to someone to hit it with another layer of primer, then paint it up.
Decks are still separate, but will go together easily. I think I want to add a little material to the bond rails, so instead of gluing the decks together, I'm going to lay a couple layers of carbon between the flanges and clamp.
