Freestyle Carbon Gen 1 BOB W/ XS1000
jahimmelspach
Having A Blast
SE Michigan
Got a couple more little things done today. Port matched the manifold to the XS1000 and opened up the the Headpipe exit (keeping the oblong shape to help with the air flow around the bend.) Talked a little port work theory with my friends dad who has been in cylinder head design/porting for over 30 years. What a wealth of information! Also finished up the exit nozzle and will probably end up getting that powder coated when I get my chamber ceramic coated.
Nozzle ready for powder or paint
Mani port matched to a SS 865.
Ready to be matched to XS1000
headpipe @ 51.33mm
Removing material
Finished product
Diameter using a perimeter gauge: 52.06 mm
Diameter using perimeter gauge: 51.9 mm
I couldn't find a head pipe gasket and want the head pipe to match the mani porting perfect. Could have eye-balled it, but I have plenty of time.
Joe
jahimmelspach
Having A Blast
SE Michigan
Just to show my dedication to the sport... Me at my girlfriend's cousins wedding this past weekend. on my phone, on the X haha whoops. you can see the site banner/ad on my phone.
jahimmelspach
Having A Blast
SE Michigan
Just finished a paper for my last final and look what arrived at the door!
Thanks Steve (Aquaholic) for the nice TBM flywheel.
Schools out for 3 weeks! time to get the ski painted and assemble the rest of the motor/electronics.
jahimmelspach
Having A Blast
SE Michigan
After all of the sanding and fixing of everything that wasn't right or had gotten wet.... The exterior will be ready for paint by the end of the week. I am picking up some carbon this week to add a little in the engine bay over the engine mounts, and inside front of the ski, along with under the pole bracket area.
Also sanded on the X metal pole to get that ready for paint, will wet sand it with 400 hopefully this week.
Back at school means thermal fluids, circuits, and dynamics! yay.
Break wasn't as ski productive as I may have liked being that christmas is crazy around the bakery.
Time to get the ball rolling spring is right around the corner...even if it is a large, cold, bend. it's coming!
Still aiming at having it painted and ready for assembly by the end of january.
Then the more exciting and pretty pics will be up.
until then, heres some ugly pics.
PS. sorry some of the pics are not rotated, I must not have tilted my phone enough.
Michigan
About ready to go off to paint, being that this was a full carbon hull pretty much ment for flatwater only and we like to ride bigger water(almost every weekend) we though it was a good idea to reinforce the inside with some more carbon, not only will it give us a added piece of mind, but It cleaned the way the engine compartment alot.
And for a small hull, it has a suprisingly large engine compartment
Michigan
Yesterday I layed up a Quickie ride-plate mold, for my ski and to make one for the Bob. For thouse of you who have not had the pleasure of dealing with the Ski Clinic and the "Fine Fine" job they did building the Gen one's, They modified the rideplate area just enough to force you to buy there ride plate, and that would be fine, if they still sold them(thanks Ski Clinic) last year we busted the grinder and Drill out and made one out of a VXR Pro plate, It did work ok, However, we wanted everything to be right, So we are going to have to make a ride plate out of the mold, then cut it up, grind it down, and then make another mold , to make a proper rideplate, I think we are going to make a couple in different lengths for Flat water and Surf
OP SJ Rideplate, First pic is the Gel-Coat, Second is some Glass and the Poly resin(that even in the garage is way stinking up my house)
