UPDATE:
After reading this and looking for similar setups this is what I am going to try out. I threw these carbs on thinking they were from a stock SJ or B1, but after taking it out for a ride this thing was smoking like crazy, wouldn't idle, and ate tons of fuel. After pulling the carbs, I found the jetting was 120L, 135H, which I thought was way too fat, so Im going to try the settings below.
Is there a couch that comes with 38mm carbs with jetting like this, or was someone messing around in there?
Let me know if you think this is about right.
Thanks,
Brand = Mikuni
Model = Stock SBN
Size = 38MM
Quantity = 2
Main Jet = 135
Pilot Jet = 70
Needle/Seat = 1.5
Spring = 95g with 3 1/2 coils cut (25 psi popoff)
Pilot screw = 1 1/4
Main Screw = 1
Gas Octane = 91
Altitude = 0 with super thick humid/hot air
Main type of riding = Freeride
Would it pass the 10 second WOT test = Yes!
Powerband = Good all around, but it really screams mid to top end.
Motor type/setup = Stock 62T Cases/ 61X Cylinders STD bore, 180 psi Head, Factory B Pipe w/ mod chamber, MSD Enhancer, FCV, Stock F/A's with 1 screen and choke plates removed, Skat 140mm 12 vein pump with 13/18.
