Carburetor (specs) Database: SuperJet and Blaster 1
madscientist
chilling with these guys.
good old p'cola
this is where i have stopped for now..
Brand = Mikuni
Model = OEM
Size = 44mm
Quantity = 2
Main Jet = 115 H
Pilot Jet = 120 L
Needle/Seat = 2.5
Spring = 95
Pilot screw = adj 1.75 turn out (not sure if correct)
Main Screw = adj .5 turn out (not sure if correct)
Gas Octane = 93
Altitude = sea level
Main type of riding = flatwater/ freeride
Would it pass the 10 second WOT test = yes
Powerband =decent bottom lots of high rpm
Motor type/setup = 62t/62t, 180 psi, b limited pipe,
GREECE
Tuning info from Jetmaniac ,the ski now rips.
Brand = MIKUNI
Model = A/M SBN new
Size =44
Quantity = 2
Main Jet = 110
Pilot Jet = 125
Needle/Seat = 2.3
Spring = 95gr, 19 psi popoff
Pilot screw = 3/4
Main Screw = 1
Gas Octane = 98
Altitude = SEA LEVEL
Main type of riding = FREE RIDE SURF JUMPING
Would it pass the 10 second WOT test = YES ALWAYS
Powerband = ?????
Motor type/setup =84 mm BB NW SLEEVES,PROX PISTONS,HOTROD CRANK, 61X CYL, 62T CASE BOTH PORTED,ADA HEAD 38mm DOMES, FP LIMITED PIPE, LIGHTEND FLYWHEEL,MSD CDI AND COIL,BOYESSEN INTAKE WITH RAD VALVES,RIVA CONE F/A
clouse22
BDB Kustomz
Lake Orion, MI
looking for specs/starting point.... 701 (62t cases/61x cylinder) single carb 44 intake...factory mod pipe, ada head (180ish)
thanks all
motozachl
uPsiDeDoWn
JAX
thanks all
Main Jet : 145
Pilot Jet : 120
High speed screw : 3/4 turns out from closed
Low speed screw : 2 turns out from closed
Needle & Seat : Stock (1.5)
Spring : 95 gram
Great thread...took me forever to find it. Good info but everyone rides at sea level.
I'm at 3500ft
62t, b-pipe, 37cc domes, msd enhancer, oem 38's stock interals except 135 main.
Think I need to go back to stock or will I be able to tune it with the screws?
clouse22
BDB Kustomz
Lake Orion, MI
Alright got another for you guys....
Dual Mikuni SBN 46s on a ported (case and cylinder) and bored (to 84mm) 701. Also running an ADA with 760 38cc domes, factory mod pipe, r&d manifold with carbon reeds
Currently jetted
Main 115
Pilot 110
Spring 95g
N/S 2.0
Any input would be greatly appreciated.
Thanks
As great of an idea as this thread is, its missing one thing. F/A type is so important to the jetting specs. For example a set of OEM 38's will need almost 10lbs pop off pressure difference to run open element filters like pro k vs stock F/A. Im not saying it wont run with the same jetting, im saying in most cases to optimize tuning there is a change needed when switching F/A.
98gti
C@R H@ul3R
NW FL
Nuklear, you seem to be the 760 guy around here, I need to order some jets and such and need a good starting point, I'm running a unported 760 with dual oem 44s, r&d rec head, bpipe mod, oem f/as. This is all in a RN. If anyone else knows what to start with or has a set up similar to this please LMK. Thanks.
Could some one help me out here possibly please. My rn is currently jetted at
140 main
75 pilot
2.0n&s
80 gram spring
high screw 1 turn out
low screw 1.5 turns out
Mods
stock 62t bottom end
Jetmaniac/ Blue ported 82mm 61x cylinder
Ada girdled head with new 35 cc domes
V force 2 reeds
Oem 38s w/ tau ceti filters
dual cooling
b pipe w/ c4 chamber opened up to 48mm
msd enhancer
Zero lightened flywheel
stator timing marks lined up with cases
It is jetted to similar to skis posted in here with tnt chamber. Ski will fire on primer but thats it. any help is appreciated.
Nope everything was out of the ski used the fuel to start a fire in the fall. I am going to open up the carbs tomorrow and clean them out then go form there. Do those jets sound right for the mods?
sorry gti I just saw your post. With what you are running on that 760 I think you will be very surprised how close to stock your jetting will be. The gp760 that top end and carbs came off of has a pipe that is much better designed then the 701 pipe so its jetting is alot closer to what's needed for the b pipe. Depending on how much compression you actually have with that head a good place to start would be. 115p 135m 1.5n/s with 42-44psi pop off. If you switch f/a at some point you will def have to lower pop. Start one turn out on top screw and one and half on bottom but prob will have to go in on both especially top screw. You can run a 130 main and leave the top screw open more. Also experiment with taking the elbow of the air box....
Hope that helps
98gti
C@R H@ul3R
NW FL
Hope that helps
Yeah that does help alot, thanks. I thought I had read before that those 64x engines have staggered jetting to compensate for the 64x electronics and the compression difference, I thought I had read the rear cylinder ran lower compression. I am now running complete 62t electronics and the a/m head so compression will be the same.
They are staggered jetted and that does need to be evened out. But that was mainly because of crank twist when put in the gp or b2. They weighed a ton and had a huge pump. The lower compression and less advance on the rear cylinder ignition timing was also done for the same reason. All that needs to be removed. Wasnt trying to say you could run the crabs right off the gp just meant the jetting is very close to what came. And honestly if you did run them as they come off the gp or b2 you prob could "fix" the difference in the staggered jetting with different settings on the top screw. The jetting is only a few thousandth difference when measured with pin gauges.
israel
hi guys i need some advise-
current:
single sbn 46 mm
main 150
pilot 120
2.5 n\s
95 grams spring
i have rn sj 2008 with b pipe on it. run at sea level. it seems to run ok maybe little rich.
i added today an ada head with 37 cc domes and some guy suggests to rejet it to-
main 140
pilot 125
n\s 2.5
115 grams spring
high 1 3\4
low 7\8
what to do? i dont have time to tune my ski so i hope someone here with experience can help me
