Carburetor (specs) Database: SuperJet and Blaster 1
chrisdoc0608
insulting
rocky mount, nc
good starting point for the following setup?
62t/61x ported cases/cylinders
msd & 3* static advance
46mm mikuni
coffman sizziler (b pipe later)
lightened flywheel
170-185 psi (dont have a head yet)
100ft above sea level
DirtyJ
Freedom aint free no more
Stock Setup
Hey Guys
This may sound like a dumb Question. I need to return my B1 carb back to stock form, sellin the ski so need to return to normal.
What size are the jets in a bone stock B1 and what size would I use with a K&N FA? If anyone can help me out it would be super. If you know the fine tuning as well that would help but its not mandatory!
Thanks Boyz:friday:
chrisdoc0608
insulting
rocky mount, nc
46mm mikuni
lightened flywheel
I ended up at 150m 120l 25psi (2.0ns & 95g)
abt 3/4 out on ls and 1.5 on h
Flash-FX
No Square..No Round..FX-1
ok so after many different configurations, i am now currently at 140m 120p 2.0ns 95g with 25psi pop off. it hits like a ton of bricks at all throttle positions other than when i hold it at 1/4 throttle then go wot. It makes a gargleing noise.... im taking suggestions as to what i need to change
Hey..chrisdoc0608,what did you end up with your pop-off setting to work out the 1/4 throttle richness...& are those duals?
This is a good thread...it needs to continue.......
GIL
Power In The Hands Of Few
Cullman AL
I have found that mine work best with fuel going thru them. ?
Feedback? hows bout yall? I think Crammit's shiz runs on magic pixie dust.
tbaer
USMC
BEAUFORT SC
i need help on a base line to start with my jetting.
i have a 61x with an r+d head making 200psi with a 46 on there right now. i just bought a b pipe(mod) and dual 44 mikuni"s w/prok f/a and r+d dual 61x manifold. I am about to put the pipe and carbs on, but i need a baseline of what jets i should put in to begin tuning. any help would be great. pipe screw setting may also help.
Kirv
torque is good
CT/NY/NJ
Brand = Novi-Tec
Size = 48 mm
Quantity = 1
Main Jet = 135
Pilot Jet = 125
Needle/Seat = 2.0
Spring = 95 g
Pilot screw = 1.5
Main Screw =
2
Gas Octane = 93
Altitude = 0 - 500 ft
Main type of riding = flatwater freestyle, occasional surf
Would it pass the 10 second WOT test = have not tried 10 seconds of WOT, only 2 seconds of WOT at a time.
Powerband = Smooth forceful powerband everywhere, pulls hard right from the bottom through max rpm. Not a peaky powerband.
Motor type/setup = Lamey 771 cylinder, stock stroke crank,
no powervalves, kawi 85 mm flat top pistons, 185 psi, TBM flywheel, factory B pipe, MSD enhancer, Riva intake w/ spacer, stock single airbox w/ 1 screen, also used prok w/ outerwears prefilter, boyesen reeds for a 'limited' setup.
shepster
Living the dream!
Blaster twin 46mm's
At last, got my blaster dialed. Here are the specs:
Brand = Mikuni
Model = Dan Lamey modified (top spray bar)
Size = 46mm
Quantity = 2
Main Jet = 125
Pilot Jet = 115
Needle/Seat= 2.0
Pop off 18psi
Pilot screw = 1.25
Main Screw = 1
Gas Octane = 95, 40:1 mix
Altitude = sea level
Main type of riding = freeride, bouys
Would it pass the 10 second WOT test = sure does
Powerband = smooth as silk, very strong bottom to mid due to pipe setup
Motor type/setup = 785cc freeride/rec ported 61x, ported 62t cases, ada head 38cc domes 0.45 squish, V force 2 reeds, weisco pistons, Factory B limited pipe and water box, Tauceti filters, Advent cdi, dual cooling etc.
this one should be easy, and factory pipe actually has their own recommendations, but not sure if they keep in mind the use of a different ignition.
I am running a 701 (61X) with a factory mod B pipe and MSD Rev Enhancer.
Also, the different weight springs, I believe they are different colors, correct? If you specifiy spring weight, let me know what color it is.
WRX Dave
Freestyle poser
Running a 61X with the stock single SBN 44 and a B-pipe. I'll be adding a head soon with 35cc domes. Anyone have an idea of what jets and needle/seat I should be getting with it? Also, should I be messing with the spring at all here?
Brand = riva
Model = powerbomb
Size = 48mm
Quantity = 1
Main Jet = 155
Pilot Jet = 130
Needle/Seat= 2.5
Pop off 95g spring
Pilot screw = 1.5 about
Main Screw = 1.5 about
return line restrictor= 60 pilot screwed into return nipple on tank
Gas Octane = 91, 36:1 mix
Altitude = around sea level
Main type of riding = freeride, freestyle
Would it pass the 10 second WOT test = yes
Powerband = good throughout but not much topend power due to porting
Motor type/setup = .5 over 61x motor with wiseco pistons. port matching and freestyle porting. decked cylinder, thrust girdled head with 35cc domes 180psi. 61x cases. boyesen reeds, k&n flame arrestor, protec enhancer. oh and a coffman sizzler pipe( like a bpipe)
im not sure why but i tried matts setup and there was DEFINATELY not enough fuel goin to my motor so i slowly jetted up and this is where i ended up. i might try and switch back to the 115g spring to see how it works but its hittin hard all around.
Brand = Mikuni
Model = Wet Jet
Size = 46mm
Quantity = 1
Main Jet = 175
Pilot Jet = 130
Needle/Seat= 2.5
Pop off= 18 psi
Pilot screw = 1.5
Main Screw = 2.5
return line restrictor= No
Have not tried 10 sec wot. Does pass 3 sec wot.
61x with b-pipe,port work and 180 psi domes.
This set up comes from 4 days of jetting. Starts first turn of starter and pulls hard.
