Quinc
Buy a Superjet
- California
Enough people here are running a Sizzler pipe so thought we should have a thread to post how you have your piped tuned, water lines ran/reduced etc.
@CRJ
@King Kang
@Brian_216
@gto0209
@B_RAD_BALLA
@SharkB8
61x/61x
754cc bottom end porting
Pro-Flo 46mm carb
190 compression
msd enhancer
Solas repitched 13/15
Sizzler mani and headpipe bored to 47 mm and gasket matched to the exhaust ports, polished and opened up etc.
Still tuning and playing with it but this is what I have so far:
@CRJ
@King Kang
@Brian_216
@gto0209
@B_RAD_BALLA
@SharkB8
61x/61x
Pro-Flo 46mm carb
190 compression
msd enhancer
- Tapped for dual cooling
- Cooling line running from the headpipe to the pisser reduced to 3mm (dribbles out the pisser)
- Stinger line has a valve that I have been slowly closing off to see if there is a difference
- WOT RPMS are currently around 6500 +/- 50
- Chamber gets hot but does not sizzler or steam off water.
- Head pipe is a little warm to the touch. Should probably get one of those laser temp readers..
- Bottom end is snappy, but I am not sure if it is as good as it is going to get or still has room for improvement..
