Im sure that it will rev higher with a taller port and/or shorter tuned length, my porting was 120/182. Once you get the pump load light enough for good response the pipe will go rich and wont rev much more. Small CC engines struggle getting on the pipe with much more than a 9-15. A programmable ignition and high compression will help a lot with that issue allowing a little steeper prop.
I will also be at 83mm bore, it will help a little but its still only a 736 ported and matched, epoxied cases and fingers with heavy porting.
Regarding the pipe going rich, I have never heard that term before.
