the Coffman's has a couple of great sweet spots with 701-760 engines, its secret lays in the water restriction and will differ with water routing dual or single... also head pipes differ with 2 or 3 pissers.
From my experience >> The pipe itself should not be dried out so much that pipes actually sizzles , a good starting point for dual cooling is to restrict head approx. 4 mm and the stinger side approx. 3 mm. ( if you don't have a flow control valve ).
Our jetting was always run with a 1.5 N/S which seemed to work better than the Coffman's suggested 2.0 N/S, but we also had a higher pilot and main.
