I'm thinking about doing valves. I just towed a friend back and we were worried about water coming in from being towed.
We decided to tow back as slow as possible since when we tow at high speed, it's like a 50/50 chance water goes in the engine.
We went so slow and it took forever. Got back and pulled the plugs. Ski was swamped......
I can see the argument "another thing to go wrong" but, how.... It's a valve...
I also understand the argument of just towing it and un sinking it back at the ramp but, usually we go to the beach to try and fix the problem before we tow anyway so if your on the beach and you decide it can't be fixed, just close the valve and tow home.
It's super lame having a swamped 10mm stroker motor in the first place. Let alone an engine that is swamped and due to an issue of it getting towed in the first place, it can't get running with out some serious work and is now on a race against the clock to either fix the problem then get it running then put it back in the water or decide to either fill the engine with oil, or disassemble the motor entirely to save the crank.
Example, I just had a ski that had an electrical melt down and would not turn over since the ground from the stator to the ebox melted. On the beach we could have just turned the valves to off and then tow home and sort the problem. Instead, we towed home, the skis swamped during the tow, and now we have a bigger problem.
A swamped ski with no way of getting the ski fired back up and put back in the water.
We had to flip the ski to get the water out then fill the entire engine with oil to save the crank. Ski sat for a week with a bit of stress on everyone's mind waiting on jss to send our rebuilt stator back. Then the fun of putting everything together and not being able to see if the Cdi had been compromised from the melt down until we got all the oil out of the engine since if we hit the start button to check for spark, we could damage the engine.
Flipped the ski and shot 3/4 of a gallon of oil out of the engine and made a massive mess. Got the ski running then had to take the ski to the water and run it to ensure everything was fine.
Had we had valves to shut off the water flow.... None of that added stress and time and labor would have been necessary. Just shut the valves. Tow home at whatever speed. Then fix the electronics and start up the ski with no stress.
