I finished the side tray, front panel, and grips. I had to pull the starter motor for some servicing before i go putting my tank and waterbox in. I can install that stuff tommorrow is suppose. I need to install a nose thingy. After that I should be able to weigh it to find out if it is still lighter than stock. no gas but ready to go.
fuzzy pic of the motor with the starter removed.
So here is the setup.
1996 modified superjet hull:
custom fiberglass rideplate
Jetdynamic scoop grate
blueprinted OEM pump with bored reduction nozzle
skat swirl C-75 prop with TBM supercone
carbon wrapped OEM handpole
modified turnplate
modified blowsion fat clamp
Pro Taper bars with sweep and rise
blowsion trigger
turfed odi grips
modified 24/7 carbon chinpad
custom stainless lowered pole bracket
WCF hood and nose piece
XFT footholds
Hydro-Turf
Umi outlets/pissers
Under the hood:
DASA 771 powervalve motor
V-Force 3's
R@D intake
Dual 48mm powerbombs
Pro-K's and outerwears
MSD Total loss
B-pipe, mod chamber, stinger mod
Jetworks flow valve
modified X-metal noise box
550 gastank with dual pickups
custom alum battery tray
Deka Etx9 battery
Umi couplers
OEM cover
