sjetrider
- in the 615 (Nashville)
IMO if your looking for longevity and are on a budget I would recomend the DASA 865 but put ALL the GOOD bolt ons on it. PFP,T/L,49mm full spec carbs. The bolt ons mean as much as the shortblock. If you do a 5mil stroker ($1100 crank) and high dollar 94mm pistons with minimal bores before resleaving and bolt crap, pipe, elecs, and carbs on it you will have the same money invested with the same power and a higher risk motor with higher rebuild costs.
If $ is no options buy all the good bolt ons and an x-scream 1200 motor, beefier crank and same piston costs. The 1200cc 66E cranks last for ever even with water injestion.
All the 89mm DASA motors with the 89mm bores are pretty proven regardless of the crank length. DASA ports them and gives them very consevative squish for longevity IMO. But, they all need the HIGH $ bolt ons to obtain maximum power. The DASA 1000 is very proven and VERY POWERFULL with the right bolt ons.
Dont forget you have to be able to put the power to water as well. The 865 works well with a 144mag, the 1000cc really likes the 148mm mags and the 1200cc you leave alot of power on the table without a 155mag
I looked at the Powerhouse Performance......Was leaning toward Dasa just because it has been around longer and is more proven. Would love to ride them both or at the very least get more feedback.
Thought about a longer stroke but $$$$ comes into play.
At 4mm I would think stock length rods would be okay for longevity and wear right? I am also trying to keep a reliable motor that I'm not tearing down all the time for top ends.
