Freestyle DASA MOTOR SETUP's - list your tuned package.
DAG
Charlotte, NC
Since it seems like these motors require the full package to really feel the major gains, I wanted to see how everyone is putting there package together to see if there is a trend for what will and will not work.
Trying to collect Data. Not trying to turn this into a discussion about the motors. Please just post 1 time. Motor package setup only. please
DASA CC
Bore –​
Stroke –​
Power Valve –​
Cylinder Cast or Billet –​
Cylinder 5 port or 7 port –​
Porting Preformed by –​
Compression –​
CARB(S)
Main Jet -​
Pilot Jet -​
Popoff –​
PIPE
ELECTRICS
PUMP
PROP
A little info about how it rides as setup above.
DASA CC – 781
Bore – 85,5
Stroke – 68
Power Valve – Yes
CARB(S) – Dual Full spectrum 49 boyessen manifold v-force 3 reeds
Main Jet -130
Pilot Jet -140
Popoff – ?
PIPE –ported B-pipe
ELECTRICS – MSD Total loss
PUMP – Stock
PROP – 12-17 Skat trak c75 3mm cutback
Cases- Ported extreme
Gas- 98octane (europe)
Head- Ada head 26 cc domes (210-215 psi measurred)
Changes from last year will be putting total loss instead of epic.
And from hooker 10/16 to 12-17 c75 prop.
Setup total loss will be 8500 rev limit
28 degree initial timing
5500 retard start 9deg of total retard.
Only freestyle setup
DAG
Charlotte, NC
Added to the first post.
Cylinder Cast or Billet -
Cylinder 5 port or 7 port -
Pablo
sqeez bth levrs & lean bk
georgia
I'll throw mine out there for you:
DASA CC – 900cc
Bore – 89
Stroke – 73
Power Valve – yes
Cylinder Cast or Billet – billet
Cylinder 5 port or 7 port – ?
Porting Preformed by – Dasa
Compression - 190/pump gas
CARB(S) – SBN 46's on Boyesen with triple stage
Main Jet -
Pilot Jet -
Popoff – 22
PIPE – B pipe/limited, bored to 49mm
ELECTRICS – MSD TL 30 degrees advance
PUMP – 144 Skat mag/stubby cone/85 nozzle
PROP – 13/18 mag...may try 14/19 this year or a larger cone
Buckwild12
I'm moved by DASA power!
Any one care to share a good fuel and cooling line setup for this, my skins going back together next weekend and am wondering what you guys are doing for fuel line and cooling line set ups.
Mine is a 850ss, using 46mm Blackjack carbs, I have a flow control valve. And dual cooling from the pump. It's probably the same as on my old setup but the dual outlets on the head are throwing me for a loop.
Buckwild12
Gotcha, any idea on the fuel line routing? This is the first time I've had dual carbs this big. My jetmaniac 38's were run tandem with the one return feeding the second carb. I don't know if that will be enough flow for these in that configuration.
GIL
Power In The Hands Of Few
Cullman AL
DASA CC – 848
Bore –86 (Dominator flat tops​
Stroke –+5​
Power Valve –NO​
Cylinder Cast or Billet –cast​
Cylinder 5 port or 7 port –7​
Porting Preformed by –Art Gomez​
Compression –200 / ADA non-girdled w/26cc domes, squish opened up to 47thou.​
CARB(S) –Black Jack 46s, Dominator mani w/VF2s
Main Jet -125​
Pilot Jet -130​
Popoff –2.0 N/S w95g springs (MS109)​
PIPE – B mod chamber
ELECTRICS – multi channel MSD t/l
PUMP –OEM
PROP –Hooker 10/16, stubby cone, 85mm nozzle, Thrust straight pull trim
Flat water freestyle 99.9% of the time
waterfreak
I had a vision!
Vendor Account
s florida
Dasa 1000 billet 5 port
bore- 89mm
stroke 78mm
carbs- dual 49 full specs
jetting- top secret
fuel- AV gas
ignition- MSD TL
pipe- PFP
pump- 148mm Maxx stainless pump with ?? prop
flat water back flip machine with stupid power :)
Proformance1
Liquid Insanity
Vendor Account
New York Crew
DASA CC – 850
Bore –89
Stroke –68
Power Valve –PV
Cylinder Cast or Billet –Billet
Cylinder 5 port or 7 port -all DASA billets 89mm aand over are 5 finger
Porting Preformed by –DASA
Compression –185 psi approx 12:1
CARB(S) –46mm Full Specs
Main Jet -127.5
Pilot Jet -120
Popoff –22
PIPE – B MOD
ELECTRICS –EPIC
PUMP –Skat MAG
PROP –9/15
Buckwild12
Anyone have issue with p.v. clearance when using a b-pipe? Mine isn't together yet, but just looking at it, it looks as if the rear P.V. may not be able to reach full travel. Trying to get my motor drop in ready this weekend, any suggestions or words of advice on install?
Pablo
georgia
I had to do a little dremel work on my manifold to assure clearance...might have removed 1/3" wedge .
