Quinc
Buy a Superjet
- California
Only 800$! what a deal... Edit, that is a good deal considering everything posted below. *words eaten.
Thats awesome news and a really good way for people to get an awesome ignition. Thanks for the heads up I appreciate it, Im just happy to see people out there with the right ignition at a fair price . Im glad your doing this and wish you the best.Yes we do have them. The 64x systems come with everything you need and are only very clean fresh water units. The box comes installed with two custom curves of your choosing. We gut out any unnecessary 760 wiring for gauges and ect as well as shorten the start/stop harness so it's the same length as the sj unit. The stater and cover are included all you need is a block off. We carry stock, lightened charging, and TL flywheels.
If you already have a 64x system or can find a cheap one like I'm assuming Quinc is getting at we will obviously sell just the cdi. It's hard to find full systems that are very clean and this option takes all the guess work out of it, just bolt in and go! No cleaning up crusty electronics, no installation wiring, no worry of sending a fw out to be lightened, programmed however you like.
I'd like to thank Wax on all of our behalf for helping find a great programmable ignition option for guys that don't want to go full MSD TL. Just like everyone else we've rode the painful unreliable wave of the epics and everything else trying to get a good control on the Yamaha ignition curve. The bigger the engine you have the more this will benefit you. Thanks again Wax.
Breaking out your testing setup?!You know at least 99% of us were thinking it.
ScottS ordered his last week so we should have one to play with shortly.
I have been refining it further over the past couple months so it’s actually better now than it’s ever been.
Top speed is over 12,000 RPM and I’m gathering parts now to replace all the gauges with digital versions so I can automate it further plus capture data and print health reports on each component.
Top speed is far beyond anything even remotely safe at the moment. My tach tops out at 10,000 RPM and the speed dials only at 42%.
The end goal is to be able to plug in a system, select the tests I want to perform on a touchscreen and hit “run”. The system will run through all the tests automatically, capture all the data and then print off a full report. Pass/Fail, min/max, etc.
Im pretty sure it is. I took the msd enhancer out and it was a heap better with the 760 cdi that i ground the lump off on the flywheelWith our luck the OEM 760 cdi will have been better than the 62t all along
