- Fort Mohave, AZ
OK, so I just got my power factor pipe and realized the manifold is for the small 8mm bolts, my cylinder is the large 10mm bolts. So should I drill the holes in the manifold larger? At a loss...
The issue I see with inserts is the holes are tapped to 10x1.25, outer threads on helicoils and timeserts for a m8 bolt are not, they use a STI tap (screw thread insert) which is a slightly smaller diameter. I don't want the inserts backing out or pulling out...No just get inserts for your cylinder and run the m8's.
What about alignment issue? The Mani can shift with big holes and small bolts.1728215, member: 550"]The bolts arnt dowls. You can use M8 bolts on M10 holes and have zero issue.
