drill or not drill out power factor manifold
OK, so I just got my power factor pipe and realized the manifold is for the small 8mm bolts, my cylinder is the large 10mm bolts. So should I drill the holes in the manifold larger? At a loss...
No just get inserts for your cylinder and run the m8's.
The issue I see with inserts is the holes are tapped to 10x1.25, outer threads on helicoils and timeserts for a m8 bolt are not, they use a STI tap (screw thread insert) which is a slightly smaller diameter. I don't want the inserts backing out or pulling out...
As requested
