Lucifer
Jet Junkie
- Croydon PA
Name Change
:biggrin::biggrin:Yes, this is still the same build...... Just changed my user name
wow those ports look huge, good looking ski
Nice build! I do love those SN's. Can't wait to see how this one turns out.
Stredman, hope this helps you out.....
Heres a few more pics of my tank mod. I reused the original filler assembly and glassed over the hole where it was.
The yellow mark on the tank is where the hold down strap used to sit. I had to cut into one of the "bumps" that keep it from moving and then sanded down the part that was left. I should still be able to use the strap even with the filler neck in place.
I drilled pilot holes for larger screws (#10 x 1/2). Since the top of the tank isn't completely flat, I used a heat gun to make it pliable, put silicone on the filler neck seal, and then screwed it into place.
Its not in the pics, but I'll clamp a plain rubber cap over the old fill hose neck on the front side of it.
Its not real flashy, but worked out real nice n saved me money that will be put to better use in the engine or pump.
[EVIL][/EVIL]
I did essentially the same tank mod except I cut the fuel line inlet neck off and installed the fuel filler in that spot and then used the original filler hole as my fuel line insert. It took a little modding to get the fuel pickups to sink right, but I only had to cut the tank once and didn't have to fill the other hole. Yours looks real clean. Nice work on the whole build. Long live the square.
