Lucifer
Jet Junkie
- Croydon PA
Question
bump bump
bump bump
Sweet color! It looks close to what I went with on my 92SN. Looking awesome... Keep it up.
yeah very nice ski. i am getting ready to start my 93 sn build and i like the gas tank idea to fix mine that way. great job cant wait to see it finished.
Just make sure the sealant is ok for use with gasoline and you should be ok.
I belive the blue RTV is good for use with gasoline...
Ive used 1211 on a fuel tank, it did not work all that great. Adhesion only lasted for one or two tanks.
1211 isn't an adhesive, it is a sealant. How in the world can it peel off if you are using it to seal? Use the 6 screws and only use it as a gasket material.
it broke apart and fell into the tank, thus losing the adhesion between the two sealing surfaces.
