- sask, canada
Rhaas make custom mounts that are a few mm shorter than stock.My pump is shimmed like that already and it's still 1/4" to high or more I'm going to need custom mounts I'm thinking
You had them in a Q8 with Yami motor? And what do you want for themI have some if anyone wants some
How much?
Im looking for some help getting a 701 mated to a yami 144 in a micro. My midshaft is definitely too long and I have not been able to get a hold of eric to see if he has a shorter midshaft. What are you guys doing to solve this?
Used regular sj mounts in all 3 I built
Sooo, since I've been through this issue: EME sends a fx1 shaft, then requires you to have couplers machined down to fit, kinda crappy.
What I discovered...
To get yami stuff to work with the micro:
-gp760 midshaft (Shortest yami shaft. Get it from jetmaniac, he has the ones with the correct spline location.)
-ADA Kawasaki 1100 conversation coupler for the midshaft side, it fits the yami shaft. Same thread.
-ADA Yamaha crank side coupler
-Damper for couplers
-Several cases of beer and lots of cuss words
-In extreme cases the title for your ski, so once your really tired of screwing with the micro you can sell it and buy a superjet, see avatar pic![]()
This worked perfectly for me. With minor modifications to oem superjet mounts I was able to get the engine aligned.
Does anyone have a micro ride plate for sale? Mines getting pretty banged up and I've been unsuccessful getting at any response for eme for the last month or two
