OCD Solutions
- Rentz, GA
First off, I think the weight of the Blaster would dictate that it goes on the bottom, for safety and for ease of loading.
How much taller is a blaster than a SJ? The chinpad of the lower ski only clears the bottom of the upper 4x4 by a couple inches and the upper SJ barely clears the top of the door so there is not much extra room.
If you were to mount the lower set of bunks directly to the floor instead of on the 4x4's then you would gain 4" right there. You could shave some height off the top too if you replaced the upper 4x4's with something with a lower profile but equal strength.
I recently aquired some solid fiberglass sticks that are 1" wide by 1 3/4" tall and up to 30ft long. (The scraps I got are all between 5' and 8' long). They are fairly heavy but very strong and compact. I set one stick up on edge over a 6' gap and measured less than 1/2" of deflection in the center with my 195lbs standing in the middle. That is more than capable of holding the weight of 2 skis and way less bulky than 4x4's. The drawback is the weight and getting fiberglass stickies everytime you come in contact with them. Sanding and painting them is going to be a must.
Sent from my Droid so spelling mistakes courtesy of Android keyboard.
