hfthe3rd
NewYork Crew
- Buffalo , NY
Lucky!!!!!!!!!!!!!! Nice buy rockstar!
nice what that cost e rok
sweet!
will you git er done by wavedaze?
Damn you Eric.
Sweet New Hull Man!! I like the over the head pics... check it out.... Hahahaha
You have to turf the rails, what else would you do with them?
Carl's Freak with painted rails looks pretty sweet. But I know I bang the rails on mine frequently enough that the paint would get messed up pretty quickly. In fact, I initially left the nose unturfed (painted).
It lasted for a month before I had to cover up scratches/gouges with turf.
I ground about 1/3 through the metal ring on the pump seal. You might need to grind on the pump itself for a bit, too.
Why did you want to install the pump inserts yourself?
Looking good so far. I want either a single pole bolt with spring or a Cold Fusion spring setup.
Edit: Don't forget to put nose foam in!!!!
Looking good Eric ! Can't wait to see you ride the ski and get a ride report .
I had given my stocker away, so I used one of those sheets of pink extruded polystyrene you buy at Home Depot - the stuff people use to refoam their ski with.
I cut it into slices, glued them together with EPS glue, and then shaped it to fit.
The wide trays are the bomb! l love mine on the Rok hull.Hard to go back to a sj tray! Can you take a pic of the tray to see the pump insert install from the top? thanks
I can't remember now if I use SN or RN nose foam. I think it was RN. I just hacked the top of it off with a saw and it seemed to fit pretty decent.
I am using a limiting rope, but I with my X metal pole a little piece of turf glued to the hull seems to work as somewhat of a pole stop. I prefer to rely on the limiting rope though.
