D-Roc
I forgot!
- Dirty River Rider
Good I was thinking your a tad rich as well with the way you have your idle set. So you could raise the idle a bit to match your low screw setting. Or if you like your idle rpms lean the screw in a bit to see if it cleans up the idle. If set correct it should idle all day. If not it will slowly loose rpms and get rough idling until it floods ands stalls out.
