FL-cracker
X-H2O
- old exit 72 Melbourne
Put some chop on that bad boy!! Why stock length?
Alot of reasons actually.
BR's are way better with the full length.
The boat doesnt loose any bouyancy.
And I really don't know how to explain what it does for backflips... but I think it goes something like this...
the boat with a full length hull will travel higher off the setup wake (as it leaves the wake later) allowing for more air-time to make full rotation (as well as a flip with more height), as we both understand that it will rotate slightly slower then a short hull.
A shorter hull leaves the wave sooner, allowing for faster rotation, but less height. :27:
I hope this makes some sort of since :fingersx:
But besides that shorter hulls suck for everything but Backflips and flares anyways :hitwithrock: :thumbsdown:
There is reason behind the madness.... if a stock length hull works good for backflips and is far superior for all other tricks over a short hull, then why go shorter :thumbsdown:
