- Central Illinois
I'm gonna throw my guess out there of a top deck weight of around 16lbs and a 4lb hood. Screwed, glued, and tattooed will bring it to about 48lbs ready to bolt on the goodies. What is your guess @air blair??
Trying to figure out if we're putting foam in or not, I personally don't think it's necessary since I'm not known to sink skis lol and it would save me money and time on a scupper but we'll see what ends up being the best wayI imagine you'll hit your mark. Motor mount mounts, bonding adhesive and inserts. I would assume no foam if your going light. My foam in tray always adds 6-8 lbs
Thought about making some thin carbon ribs that run under the holds, almost like thin bulk heads but foam might be less workEither way you slice it. Your hull is lighter allready and that in itself will handle much better for your style. The layup is strong. Option could be to put footholds in and layer Kevlar across whole tray into holds. It'll give you some flex without break
Lay up 2 carbon panels that can be trimmed and epoxied to each side of the pump box to support the tray directly under your heels. Fit pink board insulation up and around your scupper tube and exhaust, then add a little pour foam through the tray. Was the lightest/ strongest combination I could come up with. Joe knows what he's doing. That carbon can flex a little bit before it breaks.Thought about making some thin carbon ribs that run under the holds, almost like thin bulk heads but foam might be less work
Sent from my SM-G900V using Tapatalk
I like the way you think sir! Definitely putting that one into serious considerationLay up 2 carbon panels that can be trimmed and epoxied to each side of the pump box to support the tray directly under your heels. Fit pink board insulation up and around your scupper tube and exhaust, then add a little pour foam through the tray. Was the lightest/ strongest combination I could come up with. Joe knows what he's doing. That carbon can flex a little bit before it breaks.![]()
Finally had time to get something done today, pump inserts are set and sealed along with bulk head inserts, ride plate and everything glued together and straight, hopefully plumbing next weekend followed by foaming the tray area
Never had a problem with my water line placement previously lolIf you want to make your life easy put the water lines high on the bulkhead!
I see what your saying, I usually put the hose on the lines before anything else then it doesn't matter where they are they've already been attached and clamped but I might move them upJust saying on previous skis they were low and on my dvx they were high and it was sooo much nicer
