the fear is first and fore most the landing upside down. just try inverted stabs first and a couple of pancakes first.
I think if I can just get over it and pancake a couple, a few slams will help me break the funk and try to throw down.
Freestylegeek-------------I found a vid with the title 'backflip attempt,almost there'. What engine u runnin with that attempt and is that a oem hull? You were really close!
BTW-U SUCK! u make rollin look waaaaaaaay toooooooooo easy. LOL
Engine: Lamey 793 (8mm crank, 81mm bore) non PV, Xscream 46's, MSD single coil total loss.
Hull: shortened (-2.5") SN conversion with lb XFT top deck.
That backflip attempt video was when I had 23lbs of wet foam in there. I'm sealing things back up after replacing it all with polystyrene (about 2 lbs worth). I'm hoping that (and a technique change) will get me nosing them in.
The rolls look easy because they are! When you get the right technique, there's no longer any effort involved.
... just try inverted stabs first and a couple of pancakes first.
Just do it.
It doesn't hurt (much).
Shhhh!!!:shhh:This is a lie.
Question is, where are your poles throughout the process? Should my poll be one the hood the entire time even during my pre-hop. It seems like I spin on more of an axis when my pole is right down on the hood but then I can't take full advantage of my pre-hop. Should I have it a good foot above the hood during the pre-hop then put it on the hood as I leave my set-up wake?
1) take off with a semi-upright stance. you know, a balanced athletic stance to get the most out of the hop off the setup wake.
2) once airborne, try to tighten your body up into a ball by pulling the ski to your butt using the footholds, and crouching down to get the pole close to the hood. I like to push it over with my shoulders on takeoff to get the ski rotating too.
of course you need to full throttle up the wake and the steering to the lock on takeoff.
pulling into a ball speeds up the spin to get you around. just like when you see a figure skater pull in her arms and legs and she speeds up the spin like a top.
if you take off rolled up in a little ball, then you have nothing to pull in to speed up the rotation, so start the roll open like a nose stab, then quickly and smoothly pull everything in as you're leaving the water to speed up the rotation.
they are much easier to learn off of small 2 or 3 footers in the ocean, then off of boat wakes (never within 100 yards unless it's your friend's boat, we don't want to piss off the boaters), then off of your own setup wake.
hope you get it down, it's a good feeling to nail a clean roll.
I learned through the tips on the X here and mostly by myself out on the Lake for a week while I rode my STOCK 04 for the first time.
My suggestions:
1. Work your setup wake out so you hit it from the side not head on. Usually in that case you will plow into the wave and get minimal height.
I think if you do not do what Mark says in #1 the rest is futile.... head on is no go for stock/ slightly modded skis...
maybe somebody could draw a wake setup and how you should approach - generaly everybody knows it but......
