No build thread?
Too lazy. Second Chan build. Last one took 2.5 days.
No build thread?
Using the two pieces is a bit easier and less stressful. I've done both and getting a single piece with no wrinkles or tears is difficult...not impossible. This was my first two piece job on the gunwales. I think from here on out Ill do it this way. Way back when, someone gave me some knowledge and they said: "The best turf job is one YOU didn't have to do." I hate turf above all other jobs on a ski. MAJOR PITA.
How do you make the seam where the top and the bottom of hold meet not open up over time. Do you adhere the 2 pieces of turf together and then trim?
Totally agree on the PITA. Turfing is by far the worst job.
Yes going to wrap my holds together with contact cement then trim it. Yes turf is a major PITA and time consuming.How do you make the seam where the top and the bottom of hold meet not open up over time. Do you adhere the 2 pieces of turf together and then trim?
I ordered two black molded diamond sheets straight from hydroturf, and they have that weird texture in between the diamonds as well. It's definitely different.This last batch of turf I got was suspect. One sheet was the good, old standard issue black diamond with usual thickness. I ordered another sheet to use for another ski. I don't know of HT is changing their formula or if this is knock-off HT. Its thinner overall and the grooves between the diamonds look to have a been imprinted or textured from some process other than the usual "cut" diamonds. I guess it could be molded rather than cut. Being thinner material, I bet it conforms easier with less heat but durability is my concern. I think this last sheet came from hot products.
Got a pic?I ordered two black molded diamond sheets straight from hydroturf, and they have that weird texture in between the diamonds as well. It's definitely different.
Sent from my XT907 using Tapatalk
Can get one when I get home from school.Got a pic?
That's not what we're saying. They changed how molded diamond looks. I might have a scrap of the old molded diamond to compare to the new.The molded diamond turf pattern is pressed with heat. It's going to look different that cut diamond turf
I think you did an excellent job on your freak. I wasn't putting down your turf job at all or saying mine was better cuz it isn't.
I think rose was just asking why people have trended towards having separate pieces on the top and sometimes the bottom of the holds. I have only turfed 5 skiis so I am far from an expert.
So this is what the X has come down to lmfao !Sanoman always starting drama!
Impressive! Looks like you could have covered that little visible glass if you had some extra turf, or would it probably almost crease there? That bend was annoying on those holds lol.Oldstyle holds the patch is for where just change the patch
