chadman154
#Itsonlymoney !!!!!
- Dirty south
It wont be the first time we tried doing chicken set ups lol
Those are 2 of my chickens!!!!
Cut that prop back on the lathe some more. The bottom the blades should be as close to the stator hub as you can get them. Like a piece of paper away from touching.
Hey, some actually helpful adviceCut that prop back on the lathe some more. The bottom the blades should be as close to the stator hub as you can get them. Like a piece of paper away from touching.
You need to do it locally. You'll have to re-install the prop and check after cutting, then make the decision to cut more.
Easier to cut multiple times than take too much off in one shot and have to shim the prop back off the stator.
I'll run it this weekend, but it's something to play with to get the max out of my wimpy 701Or if you don't want to do this just run it.
I would get the options of several builders and prop manufactures before you take one post as Gospel. Just run itI'll run it this weekend, but it's something to play with to get the max out of my wimpy 701![]()
Are you being serious and telling me it's okay to be a stubborn little punk as usual and question the advice thats already been given to me?I would get the options of several builders and prop manufactures before you take one post as Gospel. Just run it
Sent from my XT1254 using Tapatalk
100% true for me. I am a master overthinker. It's a trait of many engineers, lolSorry rosie, just gonna leave this here
A trait of successful engineers is getting the job done100% true for me. I am a master overthinker. It's a trait of many engineers, lol
Yeah I need mine to spool up ASAP especially for low speed flips.That's why Gil always hated a tbm pump cone on his skis. Wouldn't slip and spool up fast enough for flat water.
In surf I loved it because it hooked up great in white water.
I'm working on thatA trait of successful engineers is getting the job done![]()
All Gil cared about was his ski idling perfect for 11 hrs straightThat's why Gil always hated a tbm pump cone on his skis. Wouldn't slip and spool up fast enough for flat water.
