- Down stream of Harrisburg, PA
that looks a lot like lenzi's new boat, from the side http://www.x-h2o.com/attachment.php?attachmentid=101799&d=1260521038
Luker, I am based in Pattaya, Do you ever get over here?
Chad, Yes that is a Maxxx Pole, The CNC machining is excellent it is a very nice part.
It comes with rose jointed adjusting rods but I think when I finalise the top angle I may replace with aluminium strips for lightness as when the pole pad is on they cannot be seen.
Forming sections from polystyrene foam cut with a hot wire , sanded 40grit then 80grit, covered with glass cloth 48g or 200g then bondo works very well.
The wire can be bought from model shops, I just connected it to a battery charger and turned up the amps until it started to cut the foam. I found using a small current / slow cut was easier to control.
I have not included the foot holds as It would mean I could not use a one piece mould for the top deck, So they will be moulded separately and cut in later also the placement can then be set to suit the height of the rider.
We will hopefully get the first primer on today ..
Manage Attachments
