Freestylegeek's squarenose conversion
freestylegeek
waiting...
Grand Rapids, MI
does the top deck weight include the weight of the hood? Small gas tank and battery will help as well. You will also save some weight running just a front exhaust.
No, it does not include the weight of the hood.
I am strickly doing a bare hull vs bare hull comparison.
I realize I will loose a little weight in the hood region since my old hood was 17 lbs, and the new one is 12 lbs.
AIRICCC
tubbies is/are the answer
im a little late to chime in... geek, are you going to use sergio's firewall scuppers that dump into the pump cavity or just the tube style? are you doing the rear side exhaust exit as well? lookin good!
AIRICCC
another thing... when I was in the build process I replaced that old steering cable thru-hull housing with a nice piece of anodized aluminum... I used one of those tubes that they put inside RC airplane wings... my intention was for easy installation and removal of the steering cable as well as it not having to flex as it goes through that tube, plus the seal on the oem one did not look sufficient... just an idea... i think it was either 7/8" or 5/8", I can get you in touch with the place that had it, it was only $12 i think...
freestylegeek
waiting...
Grand Rapids, MI
Never too late my friend!
I will be using a standard 2" scupper tube, and an X-metal scupper.
I will also be doing the side rear exhaust (with the XFT outlet).
I'll have more pictures of it soon (maybe tonight).
freestylegeek
waiting...
Grand Rapids, MI
I'm not too worried about the steering cable tube.
The OEM on the '94 is a heat formed piece of PVC so it's a little more rigid that the 'sealtite' that is used on the '96+.
Good idea though!
freestylegeek
waiting...
Grand Rapids, MI
The scupper tube is installed and sealed (3M 5200) to the bulkhead.
Now before everyone gets all huffy about me using schedule 80 PVC, it's really not adding that much weight. The whole assembly weighs 1.5 lbs, and it's displacing almost 1 cubic foot of foam (which weighs 3 lbs). So...I'm saving 1.5 lbs! yeah that's it!:biggrin:
Besides, I had the PVC in the garage, and I spent a little over $1 on the fittings.
:EDIT:
I didn't have any coffee before those numbers were posted.
I'm actually only saving about 1/4 lb of foam.
So, the weight addition of the scupper is 1-1/4 lbs. :)
F
Freestyleriverrat
Guest
getting closer and closer :Banane01: Have any pics of the top deck sitting on the bottom deck?
