freestylegeek
waiting...
- Grand Rapids, MI
it's in my living room :wiggle:
Ah ha!:headbang:
Nice progress. Do you plan on leaving all of the lip?
i only recommened it because i've run them that way for several years in 2 of my skis without issues, you can alway drill and new dowel pin if it's a concern.I've thought about that Tom, but I'm concerned about spinning the stator section. I only use 3 of the 4 long bolts that hold the pump assembly together, so without a dowel pin, there is nothing other than those bolts preventing the stator from spinning.
Now I realize my motor isn't making a TON of power, but there has got to be a reason the factory designed the pump that way, right?
This is definitely my favorite thread on the X right now! So excited to see this thing in action next spring:Banane01: Now I wish i wouldnt have aborted my conversion :frown:
Couple questions geek. Are you going to alter the rear corners of the hull at all? ie get rid of the sharp corner to make rolls easier (like you pointed out on lenzi's 05 boat).
And can you explain this Di-venycell foam to the rest of us? whats the benefits/hows it work?
Thanks buddiiee:woot: keep it up
Who's square is that in the picture?
Nice looking work, the relocated steering cable is the best. It looks like xft makes some nice stuff. Get posting pics
Seems as if you have realy done your homework. This hull should perform beautifully. Cant wait to hear your conclusion on how well the ski works once complete. Are you gona weight the hull for us![]()
Absolutely!
Here's how everything stands right now:
OEM bottom - 56 lbs
XFT top deck - 13 lbs
3 yds of 9 oz biaxial twill weave - 2.25 lbs (I won't use all of it)
1 yd of 7 oz unidirectional glass - 0.5 lbs (I won't use all of it)
1-1 ration of epoxy to glass wieght (actually, lets assume 2-1 for error) - 5.5lbs
3 cu-ft of 3lb foam - 9 lbs
Total assembled weight: 86.25 lbs.
We all KNOW it will not weigh this much because I will not be using all of the materials listed above.
Even if it did though, I'd be ok with it because the old hull was 120 lbs.
