Full size truck ski deck build.
Mine is 7 ft wide. I raised the center bunks 3 inches so the bond rails of the skis overlap and I can fit a blaster on the center bunks with wide skis like the chan on either side
R35P3CT
Let's play Wave Race
Denver, CO
Just buy mine
I would, but yours is quite a bit longer than mine and I like having easy access to the tailgate. I have a short bed, so my deck is only ~70" long
I have to thank you though, you were my motivation to build one...now I want a nice metal version to replace my wood v1 deck.
If you build a metal one I recommend building a box frame inside the bed to support the weight. My ski deck is not actually sitting on my bed sides. I'll post a pic in a few with the tailgate open.
jeremy chambon
Need more power
rockford MI
@OCD Solutions and others do you notice a scary big handling difference with weight this high? I’ve almost got mine done but I’m a little concerned since it will be on a 1/2 gmc. Mine will fit two blasters or three stand ups.
OCD Solutions
Rentz, GA
I only got to use mine a few times before I sold the truck but it wasn't bad with just 2 skis. My truck had rear sway bars and airbags though so I'm sure that helps.
You feel it for sure but I wouldn't call it scary.
jeremy chambon
Need more power
rockford MI
Yeah didn’t know if it made 75mph on the high way a little to much or not. Sounds like I’ll just slow it down a bit in the mountains.
OCD Solutions
Rentz, GA
Dually's are rock solid! I used to run around 100mph with 2 sleds on my deck and there was no roll whatsoever.
The only time I ever got scared was when I strapped my 300 gallon water tank (2500 lbs) to the top of my deck instead of taking the time to pull it. $2 worth of water left the level about 12" from the top and allowed for way too much sloshing around.
From that point forward, I spend the extra dollar to top the tank right off.
Wasn’t a huge difference but you sure noticed that extra weight up top when there’s two or three skis. A little different with a lifted truck since a it’s already high up.
I’m switching to a dually so it should be an improvement
jeremy chambon
Need more power
rockford MI
Okay I’m glad there are more people with 1/2 tin trucks doing this. Today I machined the hooks for the ramps and welded them up. I have 4 days to finish it b4 Daytona.
I was in the same boat last year. Finished mine the night before we left to drive down! I want to check this out in Daytona
