Freestyle FV-PRO Flatwater Shenanigans
eastcoastjumper
James
Long Island
First run went pretty well, almost completely broke-in. Overall I like the ski, but it'll take some getting used to coming from a rec ski.
Its probably those goofy handlebars hahahah. Bro what are you doing, get some flat bars already and ride that ski like its meant to be ridden
Sent from my SM-G950U using Tapatalk
Plano, TX
I’ve tried to tell him. He won’t listen to me. Says straight bars are uncomfortable lol
eastcoastjumper
James
Long Island
They aren't even regular riser bars, they have sweep to them right? AND skulls!!! Hahaha
Yami-Rider
TigerCraft FV-PRO
Texoma
The skulls matched my last ski well lol. Yep, they sweep up and back, they are custom made bars. I have some new rrp non riser bars on the shelf, but for now plan to run these.
Yami-Rider
TigerCraft FV-PRO
Texoma
Went for a second run yesterday, 80F weather was nice. I have 1 hour run time on the engine, about 6 gallons of fuel. I'm liking the ski more already, just need tray time. I ran into a few issues already, figured as much lol.
The brand new thrust tank gasket has already swollen and now is leaking fuel, guess I'll have to cut my own.
My front airbox rubbed the hood, so for a quick fix, I melted it and smashed it down, I'll probably make a custom one out of carbon fiber.
My midshaft is getting hot, I think it's because my driveshaft is bent about 1/32" or less, I was hoping it would be fine till next winter, but I guess not, so got new shaft coming from maniac.
Yami-Rider
TigerCraft FV-PRO
Texoma
Pulled engine and pump Saturday, replaced bent driveshaft and rode Sunday, my midshaft is no longer getting hot :D
1.5 hours on the clock so far, each time I ride this thing, the more I like it, pretty much have flatwater 360 figured out, need to get the motor dialed in a little better and move on to flatwater flip.
Plano, TX
Good deal on figuring that out. So how warm does it get with a straight shaft?
Yami-Rider
TigerCraft FV-PRO
Texoma
did you notice a difference in vibration replacing the shaft?
No difference in viberation, shaft was only bent by .020". After idle, it's pretty smooth like most skis.
On the midshaft issue, which part of the midshaft assembly did you detect the heat in ? I Want to check mine, thanks
I touched the midshaft itself. Be careful checking it, mine was 180F with bent shaft.
Yami-Rider
TigerCraft FV-PRO
Texoma
Forgot I did take some photos.
Can see where the splines made marks in one spot of my new midshaft.
Also installed a stubby cone, need all the bottom end I can get!
