Wasn't happy with my water feed lines from the bulkhead to the exhaust manifold so I picked up 10 ft of 1/2" id air line from Lowe's for $18.
Installed with 1/2" oeitker clamps on the bulkhead and hose clamps on the brass fittings on the exhaust manifold.
It was tight getting the oteiker clamps over the tubing once with was over the aluminum tubes that come through the bulkhead from the pump tunnel...so I opened up a fender washer just larger than the od of the water hose, slipped it over the hose, followed it with a 3/4" drive socket, then once it was up against the stuck clamp, tapped it (aggressively) with a ball peen hammer to get the clamp over the hose on the aluminum tube. Once it was there, remove the socket and washer and crimp with oteiker pliers.
Turfed the bottom of the fuel tank and had to figure out a way to keep weight on the turf while the contact cement dried. Chain!
Steff bought this setup for cutting fabric at Hobby Lobby. It makes perfectly straight cuts in hydroturf. Awesome!
