Gabe & Steff's Krash Predator Build
hey gabe i counter sunk mine ! the 4 main ones and just left the 2 end ones stock ! my plate fits ok but not flush with the hull at all either! i also cut my plate flush at the end!
NC
McMaster Carr order placed. It's painfully evident that "Home Improvement" stores are not hardware stores anymore. I also picked up some replacement ODI lock on bolts because I'm drilling them out every time I need to change my grips!
Metric counter sunk bolts use a 90 degree taper. Common countersink bits are 83 degrees though. However, for bolts this size and in glass or aluminum, you can pick up a 90 degree router bit at Home Depot or such for like $6-10 maybe and get a proper taper and fit. Just pry the little ball bearing off the tip.
NC
Today I addressed the monster front "foothold" so I could actually use it as a foothold.
Thanks to Steff for getting the peeling started so I could reuse the original turf and to my Hydroturf connection aka @Bigfish for the 9 & 26 mil padding and diamond turf (which will be used later on the rear footholds mtf).
Original turf peeled up...
9 mm in the front and 35 mm + 9 mm (44 total) of padding on the roof of the foot-cave, turf glued back down and, voila! Not bad for a turf-newbie! Adjustable footholds next...muh haha!
US
new matting for mine nice and cushy not that hard stock stiff stuff
NC
Cut off the heel hooks, stripped down to glass, and glued 26mil padding under the footholds and 9 mil on top to protect me! Wrapped the whole thing with molded diamond HT. Test ride tomorrow...
photo 2.JPG photo 3.JPG photo 4.JPG photo 1.JPGphoto 1.JPG photo 2.JPG photo 3.JPG
yeh their foothold padding stinks i padded with 1 inch stuff but have not cut them i will need to try yours see if i like it that way! but i dont flip so mite not realy matter!lol
NC
Trimmed the padding off of a blowsion chin pad, reinforced it with carbon, and turfed it.
Cut up an old stainless bracket from a couch and turned it into a face pad mounting bracket. Time to mount the face pad...photo 3.JPGphoto 2.JPGphoto 1.JPG
