- Tuscaloosa, AL
Sweet
For clarity, which wave do you hit? 1st or 2nd? I have been working on it and hitting the 2nd and having a lot of trouble hitting it right.
Great write up btw! Could you do one for a setup wake for rolls too?
Set up wakes,
Use trim, go fast enough so that the ski doesn't just want to ride nose high and smack you in the face, almost on plane. Go in a straight line about 15-20' start hooking left so you make a U then straight again. The U part of the wake for flips would be about 10-12' wide. With that setup you don't have to travel that far out before turning around to hit your wake. Always look over your left shoulder and watch what your wake is doing. It's all about timing and will just take practice. Just always watch what the wake is doing so you can figure out when to turn around and hit the wake. There should just be one good wake.
The wider you make your U the further out you have to go before turning around to hit it, and the smaller the wake will be.
If you make the U more narrow, the sooner you have to turn around to hit it but it will be bigger. You can go to narrow and the good wake(first one) will die out and there will be a second one, just takes practice.
Watch my vid in the pics and vids, it has a good pov of a setup wake.
Also when going for a flip, going too fast into the flip will take away height but make you travel further. Going slower at the wake will give you more height. If you go slower, get in the gas sooner when hitting the wake.
Hope that helps
You might want to take someone with expertise in flipping. I see no one has mentioned you should let the pump settle before you rip the gas on the 180 flip attempts.
I always thought people learned from being hands on with decent instruction. Thanks again Tpain for reminding why i don't help people.![]()
I hit... or at least try to hit the second wave. I have a wicked hard time timing it right. Yes from what I know you can do a roll off a setup wake.
Billybo... no one has mentioned that here. Chadgnarly did when he was here. I have a hard time remembering all the steps... I have a few people in mind to hit up for some help. Tx.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Love ya hun and your ski and I think you are progressing crazy fast..........but my question was for Jace. Lol
