Rock on playa!!! Are you coming to Daytona? I think I am going to miss it this year. I will probably be on Oahu for 3 weeks for business.
Is the green glue the plexus stuff, or marinetex? Where do you get either of them, and do you need a special gun to dispense it?
Its Neither ... its called Pliogrip...about $40 a tube. Yes you need a special gun (about $80 )
It what oe Octanes were put together with. very similar to what Yamaha used
Eager polymer , I think near Chicago, is where I bought it from .
I would send you the gun to use, but I sent it to Goose to use last spring, he was suppose to send it back along with 2 ride plates. He has failed to send it back at this point. Much less the ride plates he said he would make. All I have gotten are excuses.
Good luck on the build.
Thanks for the offer BK I borrowed ramjets gun , so I am good to go there.
sorry to hear about your ride plates and gun . I am sure you will get your parts back soon . :fingersx:
It looks like you have about 2.100" or so from the bulkhead to the front grate attach point. Did you think of using a FX-1 drive shaft to move the motor back a little more? I never saw any GOOD pix of a completed setup yet, but it might free up some room up front. Just a idea..
Looks good!
Looks good!
I did not think about using an FX-1 drive shaft ... How much shorter is it ?
I tried using an gp800 short shaft that would have moved things back about 3 in but the splines started too deep into the shaft and didnt offer enough grab.
do you have an extra fx drive shaft?
